Need help rewirng and installing valves in Jax Fl
Page 3 of 4 Previous  1, 2, 3, 4  Next
Need help rewirng and installing valves in Jax Fl - Page 3 Empty Re: Need help rewirng and installing valves in Jax Fl
Post by POS-hardbody on Tue Feb 14, 2012 11:42 pm
Youll just have to unplug the black and gree plug from the main black box and go get that little black box from somewhere. I took mine out of a V6 pathfinder so theyre compatable and should work fine.
Post by IBDRINKEN on Tue Feb 14, 2012 11:48 pm
I just went out there and unplugged them. I'm going to go by the dealership in the morning, just want to replace it with something new for my piece of mind
IBDRINKEN
Post by POS-hardbody on Tue Feb 14, 2012 11:50 pm
sure makes sense. but try it and see what happens
Post by IBDRINKEN on Wed Feb 15, 2012 12:27 am
Once again thanks for the help
IBDRINKEN
Post by IBDRINKEN on Wed Feb 15, 2012 10:25 pm
And so apparently I have a major short some where as soon as I plugged the new fusible link in there the bitch started smoking and that one went bad. I replaced all of the battery terminals ormjusiece of mind and to figure out the issue. Nothing in the interior is working including my switch box. Any insight would be helpful.
IBDRINKEN
Post by POS-hardbody on Wed Feb 15, 2012 10:54 pm
fuck... you might have to chec every wire for the bags and such. whats the most recent things you have done?
Post by IBDRINKEN on Wed Feb 15, 2012 10:55 pm
I pulled the alternator to take it o advance to,have it checked out and then reinstalled it.
IBDRINKEN
Post by POS-hardbody on Wed Feb 15, 2012 11:23 pm
And before that? your probably just going to have to inspect every fuckin wire for any exsposed wire and make sure nothings pinched. that'll be fun.
Post by IBDRINKEN on Wed Feb 15, 2012 11:30 pm
At this point I'm thinking about taking it to,the dealership and getting having then figure it out. I'm at wits end
IBDRINKEN
Post by POS-hardbody on Wed Feb 15, 2012 11:37 pm
They could probably find i quicker. im just not sure if they'll bother with messing with a bagged truck for liability shit. but i have no idea how they go about doing that. Ed might now
Post by IBDRINKEN on Wed Feb 15, 2012 11:41 pm
Yeah right, I didn't even think about it
IBDRINKEN
Post by GreenWithEnvy on Thu Feb 16, 2012 12:44 am
Yeah i doubt they will touch it. it could be quite a few things. Id try disconnecting any additional wires from the battery and.only hook up the bare minimum.
Post by IBDRINKEN on Thu Feb 16, 2012 12:58 am
I'm just afraid at blowing more fuses which are not cheap.
IBDRINKEN
Post by NomaOnAir on Thu Feb 16, 2012 1:13 am
I would look for a shop that specializes in auto electric. They will probably have it figure out in a day or 2 . If it never did it before I would re trace anything you have recently touched that had wires going to it .
Post by IBDRINKEN on Thu Feb 16, 2012 10:42 pm
I been on infamousnissan all day long and we think we might have found it but have to track down an alternator harness
IBDRINKEN
Post by NomaOnAir on Thu Feb 16, 2012 11:54 pm
true , junkyard ftw.
Post by IBDRINKEN on Mon Feb 20, 2012 11:23 pm
Found the harness I needed and it worked but now I have a short someone else that's completely draining the 2 batteries and one being a brand new optima. I just replaced the ground wire thinking that was it but I was wrong. Im thinking it's the starter sucking the battery dry and not letting it start. Any more help is more appreciated.
IBDRINKEN
Post by POS-hardbody on Mon Feb 20, 2012 11:27 pm
Any loose connections of any sort? Faulty starter?
Post by IBDRINKEN on Mon Feb 20, 2012 11:35 pm
Everything is def tight. We are thinking the solenoid on the starter s sticking. Original I had the alternator tested with the other problem anditvwas fine so I'm going to replace it with a new one but we are leaning towards the starter.
IBDRINKEN
Post by POS-hardbody on Mon Feb 20, 2012 11:47 pm
Fuck man, try that. I kinda ran out of ideas of what it could be
Post by IBDRINKEN on Mon Feb 20, 2012 11:48 pm
POS-hardbody wrote:Fuck man, try that. I kinda ran out of ideas of what it could be
Lol you and me both. I hate electrical problems.
IBDRINKEN
Post by POS-hardbody on Mon Feb 20, 2012 11:53 pm
I couldnt have said it better
Post by NomaOnAir on Tue Feb 21, 2012 12:15 am
Is the truck just acting like it wont start or are the batteries for sure dead ?
My truck sometimes will be super slow to start or not start at all.
I have 0 gauge body to batter , 4 g battery to head ground wire upgrade , only thing I haven't upgraded is the starter ground.
Post by IBDRINKEN on Tue Feb 21, 2012 1:38 am
I replaced the ground cable from the head to the battery. It drained both batteries while trying to start the truck. I'm going to install and new alternator and pull the starter and go from there even if both test good they are both getting replaced, might as well sinc ether are out.
IBDRINKEN
Post by IBDRINKEN on Tue Feb 21, 2012 6:20 pm
The new alternator is going on in a few and hopefully it fixes it.
IBDRINKEN
