Need help rewirng and installing valves in Jax Fl
Page 4 of 4 Previous  1, 2, 3, 4
Re: Need help rewirng and installing valves in Jax Fl
Post by POS-hardbody on Tue Feb 21, 2012 6:50 pm
Thats the only thing i can think of, just weed out the possible causes
Post by NomaOnAir on Tue Feb 21, 2012 7:18 pm
I am going to put my money on the alt not charging.
If the new one isn't charging it could be a bad , Dare I say this again. Fusible link @ the battery/or in the harness.
Post by IBDRINKEN on Tue Feb 21, 2012 7:25 pm
The fusable links still work and I bought a bunch of extra ones just in case, we hooked up a meter to them both. I'm eating dinner and when I'm done ping out there to install it.
IBDRINKEN
Post by IBDRINKEN on Sat Feb 25, 2012 4:19 pm
We fixed it and it was a combo of a dead alt not charging and some fried wires. So I drove it around for a few hours and parked it and went bowling came out and the damn compressors won't come on, I checked all the fuses and they are good to go. Maybe a relay and I did get caught in a rainstorm not sure if that makes a difference.
Ok so I replaced the relays and still nothing. Any ideas of where I should start. I already checked all the fuses and they are good to go not sure where to go from here.Could it be the pressure the switch. When I was messing around with it they cut on for a split second then cut off.
IBDRINKEN
Post by Nickgeezee on Sun Feb 26, 2012 12:58 am
could be a pressure switch, take the wires off the switch and touch them together and see what happens
Post by NomaOnAir on Sun Feb 26, 2012 11:58 am
Could def be a bad pressure switch.Also I have had fuses the looked good but were actually blown.
Post by GreenWithEnvy on Sun Feb 26, 2012 12:59 pm
I have to agree with ed I've had fuses blown that look perfect same with bulbs lol.
Post by Nickgeezee on Sun Feb 26, 2012 10:05 pm
if the fuse was blown i doubt the comps would have came on when he wiggled the wires on the P.S. i could be wrong tho
Post by IBDRINKEN on Sun Feb 26, 2012 10:12 pm
I'm going to disconnect them from the battery and the relays and just run a test wire from the power to the battery and see if they cut on. Just waiting for the rain to stop.
IBDRINKEN
Post by NomaOnAir on Sun Feb 26, 2012 11:47 pm
Nickgeezee wrote:if the fuse was blown i doubt the comps would have came on when he wiggled the wires on the P.S. i could be wrong tho
Agreed , BUT I have had amps come on and show 12+v on a DMM , but clip out into protect andnot play an it turned out of be a bad fuse.
Post by IBDRINKEN on Mon Feb 27, 2012 5:52 pm
Ok I replaced the pressure switch and still a no go. Then I ran a wire from the battery directly to the compressors and they work. Let me ask a stupid question on the relays and the pressure switch does it matter which wire goes where im thinking yes. I also replaced the 60 amp and 10 amp fuse even tho they looked good anyways.
IBDRINKEN
Post by NomaOnAir on Mon Feb 27, 2012 7:45 pm
yes they do. let me get you the drawing.
Post by IBDRINKEN on Mon Feb 27, 2012 9:10 pm
I went back and double checked that the relays were hooked up correctly using this http://thorbros.com/files/how_to/wire-diagrams/compressor.gif and everything was good to go. Ok I just did and everything is good to go. When I tested the compressors I left everything plugged into the relay except the power and ran a wire to that and the compressors cut on. Also the pressure switch is ran to the fuse box if that makes a difference.
IBDRINKEN
Post by NomaOnAir on Mon Feb 27, 2012 9:15 pm
I have never run the pressure switch to a fuse. I would try replacing the relays especially if it is a bosch style relay.
Post by IBDRINKEN on Mon Feb 27, 2012 9:26 pm
They are both brand new relays, nevemind the switch goes to the relay not the fuse box it was labeled wrong.
IBDRINKEN
Post by NomaOnAir on Mon Feb 27, 2012 9:31 pm
the switch could be bad.
Post by NomaOnAir on Mon Feb 27, 2012 9:32 pm
try taking the wires off the switch an putting those together,
Post by IBDRINKEN on Mon Feb 27, 2012 9:44 pm
It's a new switch as well, so just take both wires off and touch them together and listen for the compressors to come on am I correct on this.
IBDRINKEN
Post by IBDRINKEN on Mon Feb 27, 2012 9:48 pm
I pulled off the wires ti the pressure switch. I used a wire and stuck it in each of the connectors and still nothing
IBDRINKEN
Post by IBDRINKEN on Mon Feb 27, 2012 10:56 pm
There is power coming back from the battery to the relay, I just checked it with a test light
IBDRINKEN
Post by IBDRINKEN on Tue Feb 28, 2012 12:10 am
I figured it out I'm not getting power back to the pressure switch
IBDRINKEN
Post by NomaOnAir on Tue Feb 28, 2012 1:07 am
the new switch to the pressire switch could be bad.
Post by IBDRINKEN on Tue Feb 28, 2012 5:48 am
I don't have a switch to control the compressors it's hooked up to the accessory.
IBDRINKEN
Post by IBDRINKEN on Tue Feb 28, 2012 9:31 pm
So as instructed I rewired the pressure switch and replace all the fuses again and everything works like it is suppose to thanks again...
IBDRINKEN
