POS Hardbody build
Page 3 of 15 Previous  1, 2, 3, 4 ... 9 ... 15  Next
Re: POS Hardbody build
Post by Nickgeezee on Sun May 13, 2012 2:47 am
damn home depot
Post by NT_Hardcore on Sun May 13, 2012 6:50 am
Nickgeezee wrote:damn home depot
lol
Post by POS-hardbody on Sun May 13, 2012 2:41 pm
Ok so heres what i did today
And the front isnt cut of anything because i still need my ports and dont want to cut until it is all finalized
Post by POS-hardbody on Mon May 14, 2012 9:23 am
Heres the ports, goin to pick them up from my dads shop later today.
Post by NomaOnAir on Mon May 14, 2012 6:21 pm
Not much of a Flare compared to aeros , did you make or buy ?
Post by POS-hardbody on Mon May 14, 2012 6:38 pm
Was gonna buy the aeros but then my dad told me to stop by the shop today. Turns out the plant he manages is currently running cement pillar tube molds... Such as this one. Just so happens that theyre 6" in diameter which is just what i needed. I grabbed four of them today, and cut two of the four to 10" in depth and im goin to attempt to flare an inch, to put me at around 9" in depth. This way i a mounting lip, and a nice little flare on the inside.
Post by NomaOnAir on Mon May 14, 2012 7:02 pm
Gotch , just curious I am sure they would work as is . just not flow as nice as aeros.
Post by POS-hardbody on Mon May 14, 2012 7:21 pm
Yea, im going to try one here in a minute. I got four so i testers to do.
Post by POS-hardbody on Mon May 14, 2012 11:21 pm
So flaring the port didnt go that well, this plastic is like PVC pipe plastic. A little thinner and whatnot. No biggie though, ill have these for a while i can rack up the money to order Presicion Ports. But heres what i got done tonight.
Started to cut sub holes.
Then the port holes
Very Happy
Then glued the face and screwed it on and shit.
The subs and ports arent mounted yet. Still need to get t-bolts for the subs, some sealent strip for the port... THEN 45's on the inside of the box, then fiberglass, then done.
Post by lowkota95 on Mon May 14, 2012 11:22 pm
thats badass
Post by NomaOnAir on Mon May 14, 2012 11:26 pm
how are you trying to flare ?
Post by POS-hardbody on Mon May 14, 2012 11:27 pm
Heat gun to the port until its maluable, then slowly press and rotate on a metal bowl while you heat to slowly create a flare. Didnt work too good with this plastic. Fugg it
Post by NomaOnAir on Mon May 14, 2012 11:29 pm
haha true
Post by GreenWithEnvy on Mon May 14, 2012 11:36 pm
Sounds intense lol.
Post by POS-hardbody on Mon May 14, 2012 11:38 pm
The flaring? yea it got pretty wild
Post by NT_Hardcore on Tue May 15, 2012 2:45 pm
nice work
Post by POS-hardbody on Tue May 15, 2012 2:56 pm
Thankyou sir
Post by LoudBlazer on Tue May 15, 2012 10:09 pm
I didnt notice any bracing. Single baffle of that length is going to flex. I have used and love wood dowels or a good solid 2x4. Id glue and screw one between the ports and you should be good
LoudBlazer
Post by POS-hardbody on Tue May 15, 2012 10:24 pm
Funny you said that, i have a ten foot peice of 1x1" wood, ill end up cutting it to size and putting it exactly where you said. Just waiting to pick up some fiberglass and all that good stuff.
Post by LoudBlazer on Tue May 15, 2012 10:37 pm
Not a hobby im new to lol. You plan to fiberglass the inside of the box? It most likely wont make a diffrence if your thinking the smoothness added will help get louder. If you add any glass, lay some mat or hair into the corners and angle it so it makes a 45 and it should add some strength
LoudBlazer
Post by POS-hardbody on Tue May 15, 2012 11:05 pm
Your pretty good ill give you that. But im not doing the glass for air flow. Even Home Depot isnt perfect with the cuts, which is expected. There is a little gap on the sides, nothing major at all, plan on laying some mat down to seal up the gap and strengthin it up. As for my 45s, im not the best with angles and a skillsaw. But at the shop my pops found these 1/8" thick cardboard tubing for the big saran wrap rolls they use for packaging. About 3" in diameter, so ill be cutting them into 4 peices, and glueing/glassing them in place to give a little bit of a radius in the corners. Sorry for the essay...
Post by LoudBlazer on Tue May 15, 2012 11:22 pm
I wouldnt even do all that. Just put some chaulk in the gaps first. Let it dry and lay some mat i nthe corners you want, prop the box up so the corner is at a 45 degree angle and pour the mix into that corner. Here is my first attempt a few yrs back before I learned what mat was lol
LoudBlazer
Post by POS-hardbody on Tue May 15, 2012 11:34 pm
Thats a pretty good idea, but thats going to call for a shit load of resin... How would you do that with the mat? Just lay the mat down at a 45 and resin it straight to the wood?
Post by LoudBlazer on Tue May 15, 2012 11:37 pm
I used I think 2 cans. I painted on some resin first so the mat would lay down the poured wha t I thought I needed in and let it sit. Then do the next corner. Dont need all the corners done. If possible just do the corners of the baffle the subs are on. Those are gonan be the most stressful corners since the subs are trying to pull that panel off lol
IF you just want to lay donw mat then just take a 99 cent brush, lay down some resin, lay the may down on it and then paint resin on top of it till its soaked completely
LoudBlazer
Post by POS-hardbody on Wed May 16, 2012 12:05 am
I may have to try that. That worked out good when you did it? Just fr strength or air flow as well?
