Coop's 96 hb
Page 2 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Re: Coop's 96 hb
Post by coop2u407 on Mon Jan 02, 2012 2:23 pm
At the lno show a lot of people didn't like em but they seem pretty simplified and compact for what it is.
avatar
coop2u407
Re: Coop's 96 hb
Post by GreenWithEnvy on Mon Jan 02, 2012 2:27 pm
Ya i like em clean looking imo too
avatar
Re: Coop's 96 hb
Post by NomaOnAir on Mon Jan 02, 2012 7:10 pm
Just sayin' , you already got 8 valves. I have all of the fittings to do this with 3/8" valves.
Re: Coop's 96 hb
Post by coop2u407 on Mon Jan 02, 2012 7:13 pm
Is that a special bought t or did you drill it out yourself?
avatar
coop2u407
Re: Coop's 96 hb
Post by NomaOnAir on Mon Jan 02, 2012 7:27 pm
That isn't mine , but we used to buy tee's an drill and tap them for the gauge fitting all the time.
Re: Coop's 96 hb
btw - I am pretty sure you can order them drilled/tapped from suicide.
Re: Coop's 96 hb
Post by coop2u407 on Mon Jan 02, 2012 7:42 pm
Wow. I never thought about doing it like this. I'm really glad you showed me that picture. Id like to do mine with 1/2 inch valves but its all the same. And would it slow it down by having all of them feed off the same line? I could always run one for the fronts and one for the backs. You really got my head turning now I gotta go get some pen n paper haha
avatar
coop2u407
Re: Coop's 96 hb
Post by NomaOnAir on Mon Jan 02, 2012 8:04 pm
you can set it up to run a feed line on both sides rather then just one.
1/2 valves are fast , 3/8s valves aren't to far behind in speed .
1/2 valve = 5/8 inner orifice , so 5/8 line is like perfect but way less common an hard to find fittings for locally. Stupid fast.
1/2 valve w/ 1/2 = very good , still super fast.
3/8 valve has 1/2 inner orifice so it is optimal an still damn fast.
I have fittings for 3/8s valves but wouldn't mind running 1/4 valves with 3/8s line.
Re: Coop's 96 hb
Post by Nickgeezee on Tue Jan 03, 2012 12:58 am
both bilstein and KYB make a shock that compresses down to 9.5 inches... if you need anything i can prolly get it for you just lmk
avatar
Re: Coop's 96 hb
Post by coop2u407 on Tue Jan 03, 2012 1:00 am
I'll measure tomorrow and get an estimate on compressed height.
avatar
coop2u407
Re: Coop's 96 hb
Post by Nickgeezee on Tue Jan 03, 2012 1:19 am
i believe 9.5 is the smallest iirc
avatar
Re: Coop's 96 hb
Post by GreenWithEnvy on Tue Jan 03, 2012 1:23 am
Hmm that's a clean setup ed.
avatar
Re: Coop's 96 hb
Post by coop2u407 on Tue Jan 03, 2012 1:27 am
Yeah but Idk if I want a gauge for each bag so I think I can just home depot everything
avatar
coop2u407
Re: Coop's 96 hb
Post by NomaOnAir on Tue Jan 03, 2012 1:30 am
Hrmm Id avoid home depot if you can . The fittings are not DOT approved.
BUT THAT ISN'T SAYING YOU CANNOT RUN THEM.
Just DOT's are more durable an will have the markings IF you were ever to get pulled by that one asshole cops who actually knows about DOT air brake fittings.
You can get DOT approved fittings from Deland truck center for pretty much same prices as Home depot fittings also.
Re: Coop's 96 hb
Post by NomaOnAir on Tue Jan 03, 2012 1:31 am
Also ACE have brass fittings that are better then Homedepot ,better quality that is where I get fittings from when I can not make it to Deland.
Some of the Tee's also have Dot stamps on them , for some reason.
Re: Coop's 96 hb
Post by coop2u407 on Tue Jan 03, 2012 1:33 am
:O this is rediculous. All my fittings are home depot lol. I haven't really had a problem with em. But I do have dot line. I think I can go to Amazon hose and get dot fittings up on Princeton and obt
avatar
coop2u407
Re: Coop's 96 hb
Post by GreenWithEnvy on Tue Jan 03, 2012 1:34 am
Yea they sell it all
avatar
Re: Coop's 96 hb
Post by coop2u407 on Tue Jan 03, 2012 1:36 am
Yeah that's where I went for my air line. That I still haven't run to the front. But this week ill go up to amazon and get some fittings to build that valve block. Or whatever you wona call it.
avatar
coop2u407
Re: Coop's 96 hb
Post by coop2u407 on Tue Jan 03, 2012 12:01 pm
Ok so along with taking a trip up to amazon possibly today I think im going to order these headlights
http://www.topgearautosport.com/part/A101JRHJ199/Nissan_Hardbody_1986-1997_7_Inch_Halo_Sealed_Beam_Projector_Headlight_Conversion.html
avatar
coop2u407
Re: Coop's 96 hb
Post by NomaOnAir on Tue Jan 03, 2012 3:13 pm
coop2u407 wrote::O this is rediculous. All my fittings are home depot lol. I haven't really had a problem with em. But I do have dot line. I think I can go to Amazon hose and get dot fittings up on Princeton and obt
You can run HD fittings without issues , not saying that at all . A SHITLOAD of trucks do.
They're just weaker over all then DOT fittings lol.
Deland was a good bit cheaper then amazon last time I recall.
Re: Coop's 96 hb
Post by Curtis on Tue Jan 03, 2012 8:59 pm
layin 4s had those halo headlights on his first gen blazer they look pretty good
avatar
Re: Coop's 96 hb
Post by coop2u407 on Tue Jan 03, 2012 10:17 pm
I think they'll be sweet behind the phantom grill.
avatar
coop2u407
Re: Coop's 96 hb
Post by NomaOnAir on Tue Jan 03, 2012 10:22 pm
Should look good !
Re: Coop's 96 hb
Post by coop2u407 on Mon Jan 30, 2012 2:42 am
Ok so since were goin in hard for unite I'm pulling my cowling? Off tomorrow to do my templates for ed and I'm gona pull my hood off and redo the brackets after I weld my exhaust and hopefully get my angle grinder back. I'm also gona mark up some spots for bed reinforcements. Gona be a busy couple of months coming up to unite. Might just build a box for my tent and bring that to haha
avatar
coop2u407
Re: Coop's 96 hb
Post by NomaOnAir on Mon Jan 30, 2012 7:39 pm
Sweet.
Its not looking like camping is an option .
Re: Coop's 96 hb
