350 in blazer.
5 posters
Page 1 of 1
350 in blazer.
iv found a 350 FI motor im going to buy. no tranny. going to carb it. what do i do about the tranny? want to stay auto. install is no big deal but how about wiring it up? truck wont have an ecu. is it all vacume? do i need some kinda wiring kit or something? info would be great. this is about all i cant figure out is how the tranny knows what to do in a none ecu car
NT_Hardcore- Club Affiliate
Re: 350 in blazer.
No electronics going to engine if u are going Carb. Th350 is The easiest and cheapest transmission with vacuum w kickdown. Save yourself a headache and buy swap mounts and swap headers from jagsthatrun website. Keeping it cool is always a little chore depending upon bore timing etc. I can help u out alot along the way me and my buddy have done 4 total.
Re: 350 in blazer.
layin4s wrote:No electronics going to engine if u are going Carb. Th350 is The easiest and cheapest transmission with vacuum w kickdown. Save yourself a headache and buy swap mounts and swap headers from jagsthatrun website. Keeping it cool is always a little chore depending upon bore timing etc. I can help u out alot along the way me and my buddy have done 4 total.
thank you very much man. im looking into the swap kits. if the th350 is going to be easier to install than a 700r4 im not opposed to goig that route. i kno i wouldnt have OD and i dont thnk it would be a huge deal. i dont highway drive much. i will def be in touch lol
Re: 350 in blazer.
for your situation, i think the 700r4 would be a better option but it might cost you a little more unless you can find a good deal.
Nickgeezee- Club Affiliate
Re: 350 in blazer.
still doing some research on the topic. i found a carb intamke mani that should except the distro. this isnt going to be as easy as i thought. but its no prob. im seeing they make harnesses to keep FI. any thoughts? layin4s what way did u guys go? fi or carb? looking for ease of installment. the wiring doesnt look hard for carb at all
Re: 350 in blazer.
so looks like this will fit with the lt-1 heads. carb ftw. http://www.summitracing.com/parts/NAL-24502592/
Re: 350 in blazer.
Do you HAVE a lt1 ? ( keep opti spark in mind , if so )
If not you can find a much cheaper Edelbrock intake then that one and see the same result power wise.Prolly$100-$150 CHEAPER .
You could go with a simple MSD 6a/Or similar ignition and single wire distro an that would be pretty much it for swapping over , Besides the swap parts.
Re: 350 in blazer.
i dont have it yet. but its just a mater of going to get it. its a good price and has just been rebuilt and has built heads. im not 100% on going carb but i dont care for the opti. so idk yet. one way or another the goal is to get the lt1 in and running. i kno its do-able lol
Re: 350 in blazer.
their is a company that makes a plug and play harness. but its 800$. th
Re: 350 in blazer.
all of my swaps have been carbed. honestly I prefer carb,ease of tuning etc. The 700R4 will require proper geometry of the TV cable etc. bowtieoverdrive offers the proper linkage etc for the 700r4 to only only shift properly but to have the correct fluid pressure. Also depending upon if u do electronic 700r4 or not will determine if u will need to wire anything for a torque converter lockup.
Re: 350 in blazer.
If it is in the budget , Efi LT1 is the way to go an you can always get rid of the opti down the road for caddy coil packs.
Re: 350 in blazer.
im reading about guys useing the truck coil packs as well? i think the carb will just be less hastle
Re: 350 in blazer.
a lot less hassle
Re: 350 in blazer.
carb would be alot less hassel , but the mpg staying efi would be nice.
Re: 350 in blazer.
im pretty sure there is no electronic 700R4 its a 4L60e really a turbo 350 and a 700r4 are pretty much identical except for the od and all you need is a diff kickdown cable to make it work if you plan on taking decent trips with the truck i wouldnt even consider a turbo 350 unless you plan on runnin a tall set of gears in the rear end
Curtis- Club Affiliate
Re: 350 in blazer.
Curtis...a 700r4 does not use a kickdown cable damnit! Lol and yes they do have electronic lockup 700r4s
Re: 350 in blazer.
well this got put on the back burner lol
Re: 350 in blazer.
lol I know what you mean.
Page 1 of 1
