87 Toyota pickup
Page 6 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Re: 87 Toyota pickup
Post by POS-hardbody on Tue Aug 05, 2014 4:53 pm
Emissions block off kit came in today. I still gotta buy a carb rebuild kit or new carb, one wire alt bracket and alternator, new clutch fan, radiator, annnnnnnd a couple other misc things.... But I'm getting there
Post by GreenWithEnvy on Thu Aug 07, 2014 11:57 am
More update pics!!! You are the only one making updates WTH! Bunch of slackers lol
Post by POS-hardbody on Fri Aug 08, 2014 12:41 am
ill try an get some up, and no one likes workin on trucks in this fuckin heat
Post by POS-hardbody on Fri Aug 08, 2014 1:16 am
Ok... Pictures...
Hooker Header, nothin crazy
And the recent work on the frame me an dad did the other night
Post by GreenWithEnvy on Fri Aug 08, 2014 10:08 am
There we go!
Post by POS-hardbody on Fri Aug 08, 2014 11:03 pm
So one o the other things that needs to be addressed here soon is gonna be my brake booster, and master cylinders and stuff like that. As far as i see it the easiest way for me to do this is to do a floor mounted clutch, brake, and gas pedal assembly. that way i can keep the fire wall nice and clean and everything will be inside the cab, hidden and tucked away on the inside of the firewall. My other options are, doing just a brake booster delete which will still putrude through the firewall into the engine bay, than id have to rig up a clutch master cylinder under the dash. Or i can do a firewall mounted swing pedal setup for the brake an clutch but than i run the risk of nothing fitting correctly since the tub is so gotdamn big. So in my mind, being mounted on the floor will make my life alot easier. Im thinkin of doing the "Mix Match" one withouth the roller pedal.... http://www.dansperformanceparts.com/buggy/tcbh/buggytcbh2.htm
Post by POS-hardbody on Wed Aug 13, 2014 8:32 pm
Just trynna save some more to buy more shit for this thang
Post by POS-hardbody on Mon Aug 18, 2014 12:25 am
In case no one saw on instagram, I got the engine pulled out today, now we can actually get in there and shave everything that needs to be shaved and clean the whole engine bay up real nice. There's only about 3-4 "big" holes that need to be filled and a couple other small bolt holes that can get covered too. I'm also planning on pulling the cab as well pretty soon...
Post by NomaOnAir on Mon Aug 18, 2014 10:17 am
Chea
Post by POS-hardbody on Mon Aug 18, 2014 12:40 pm
What was that talk about candy paint fire wall?
Post by GreenWithEnvy on Mon Aug 18, 2014 3:41 pm
CANDY PAINTTT!!!???
Post by POS-hardbody on Tue Aug 19, 2014 1:47 am
Ed thinks i should candy paint the firewall lol but shouldnt i worry about the wheels wells first? only the cab is tubbed, if i paint the firewall now... it will just be ruined once the fender wells go in. Should i grab two steel trailor fenders from tractor supply and request a day off work?..... Ed chim in on thissssssss
Post by POS-hardbody on Tue Aug 19, 2014 1:51 am
Oh and another thing, i pulled the front control arms, and everything. Got in the engine bay with a wire brush and started getting all the gunk and shit outta there. I got the driver and passenger cab tubs completely sealed with seam sealer too. I noticed today, pulling all the suspension stuff out, that the bag is rubbing a bit where we notched the frame in the front. So i took the flap disk to it a lil bit tonight, imma do a lil more tommorow. and see if the bag still rubs. I might snatch the core support off too... i might wait... Do work.
Post by GreenWithEnvy on Tue Aug 19, 2014 3:31 pm
Damn bro, you are killing it! I personally wouldn't candy paint an engine bay that will see dirt,rocks, mud etc. I would def. try to get some wheel wells in there!
Post by NomaOnAir on Wed Aug 20, 2014 8:20 pm
Lol I was jk about the candy. That would hourrrrs of body work to make it worth it.
Post by POS-hardbody on Thu Aug 21, 2014 2:38 am
Lol it really would. Every single imperfection.... Lets not forget theres alot... Would show.
Post by GreenWithEnvy on Thu Aug 21, 2014 4:36 pm
So what day do you want us to come back over Smile
Post by POS-hardbody on Thu Aug 21, 2014 6:04 pm
Not too sure, schools startin this Monday so ill be slowin down a bit. But once I get back in the grove of school, maybe I can request a day off an we can find something to do lol
Post by POS-hardbody on Wed Jan 07, 2015 10:51 pm
This may sound kinda bad... but i wonder if this truck will ever be done... im sitting there in the garage today lookin at it... and the amount of work that still is needed to be done is just enourmous... it really is. A nigga is gettin a lil discouaged...
Post by NomaOnAir on Thu Jan 08, 2015 12:35 am
lol ur crazy , technically.. if it wouldN'T of become a full on build it coulda prolly been driving by now.
I say next build day , we get the cab off ( you could have that ish ready to come off ) . We yank that bish off . Finish weld the rear end parts , get that shit in some color.
Post by POS-hardbody on Thu Jan 08, 2015 12:39 am
Thats a good plan, I still gotta figure what I'm gonna do for fuel, mounts for things, shit like that
Post by lowkota95 on Thu Jan 08, 2015 12:48 am
Its sooooo close to being driveable it will get finished bro leep your head up. Get a rendering done of it shit loads of motivation
Post by GreenWithEnvy on Thu Jan 08, 2015 12:52 am
Let's do this... now.
Post by POS-hardbody on Thu Jan 29, 2015 3:20 pm
As we all know... Cab has been removed. Engine thrown back in for now, tranny crossmember is in(Thanks Ed!). And thats pretty much where we left off that night we were all at my house working on it. Since than, ive got the engine more stripped down(Intake removed, exhaust studs removed, a couple brackets removed), and the most of the engine has been wire brushed and wire wheeled and is nearly completely cleaned and nearly ready for paint. Ive gotten most of the excess metal from the factory crossmembers off and ground down smooth... Basically from the frame horns to the bed mounts the frame is pretty much ready for paint, still have a lil more metal to grind down smooth and stuff. The rear axle, wishbone, and link bars have been removed, but im probably gonna have to put it all back on to figure out where im gonna mount tanks and compressors etc. As of right now... Heres the things i need to get done.
Clean whats left of excess crossmember metal
C-notch crossmember
Cut and box off the notched crossmember for the driveshaft
Figure out compressor, air and gas tank mounting points(gotta figure out what tank im gonna run first)
Fishplate and box off the rear c-notches
And than the frame should be ready to be painted.
After that, i gotta paint the enigne, intake manifold, order a new intake block off plate(i bought the wrong one)
Get a new carb and adapter kit
Gotta get a fuel pump and regulator and line etc.
Figure out how to setup my brakes and lines and stuff.
Finish the driveshaft tub inside the cab, patch up some holes in the floor board.
Figure what im gonna do for a windsheild and the seal for the windsheild.
and.... yea thats all i can think of right now. Thats the majority of the stuff.... Fuck.
Post by NomaOnAir on Sun Feb 01, 2015 11:15 pm
Shiznuckalezdowork... when I get bk
