Need help rewirng and installing valves in Jax Fl
Page 1 of 4 • Share •
Page 1 of 4 • 1, 2, 3, 4
I'm not sure where this goes so If it is in the wrong place please move. I'm looking for someone to help me rewire and install new valves on my Hb and maybe a tank. I'm colorblind so wires are not my friend. I have 8 1/2in SMC vales that and would like to install reducers never used them so I'm clueless on them. I'm located in Jacksonville fl. Im willing to drive but not to far. I have some rims that are painted silver with metal flake thatbimwill trade off for some help.. Im currently running a manifold and not sure what fittings I will need. I guess I'm just damn clueless. Any help is much appreciated.
IBDRINKEN- Club Affiliate
Re: Need help rewirng and installing valves in Jax Fl
Which kind of manifold are you running ? ? I can help you as much as possible over the internet as I am a few hours away. I am sure we could get figure out a way to get you through it .
You could use 18awg speaker wire , the one with copper/silver wire in it .
(Can you tell the difference in the darkness of the wire ? Sorry dont really know anyone that is completely color blind.)
Not thread jacking... But imma need to see pictures of this HB...
It's running the cheap ass airbagit.com. I don't mind driving it's just that with the 1/2 valves and the 5 gallon tank it drains it once I raise it up. I want to install a second tank not sure if I have room under the bed. Here is pic of it today completely raised since it was frozen his am.
Damn that joker looks NICE !
Hrmm , I usually only run 5 gallons on all of my trucks with atleast 1-450c viair with re7s , with both 3/8 and 1/2 valves of different trucks.
Are you running
this one (A)
or this one (B)
this one (A)
or this one (B)
Damn thats real nice! you did the work yourself
Thanks...I'm running re-7 all the around with 2 viair 480 compressors. I'm running the second one and it's shit. A friend of mine built it but ran out of money as you can tell from the damn valves so I finished it.
NomaOnAir wrote:Are you running
this one (A)
or this one (B)
its sweet, carry on with the valve talk
is it the lug and play version or do you have to wire the valves ?
An did it come with a wire to run from the block to your switch block ?
On the manifold? I'm not sure Howe wired it up as I didn't do it. Here are a few pics I just took.
Some of the wiring
ah that sucks , looks like he cut the clip.
While I know this wont do you any good unless you have someone that can help you with the colors.
Black - Front Left Up
White - Front Left Down
Blue - Front Right Up
Grey - Front Right Down
Yellow - Rear Left Up
Brown - Rear Left Down
Orange(WL)/Purple(AE) - Right Rear Up
Green(WL)/Purple(AE) - Right Rear Down
And it looks like it has seperate ground wire coming of if it/
And to make worse the damn Avs switchboard is wired backwards wtf. It's a cluster. That's why I'm replacing everything so I know it right. I don't mind driving if someone can help me with the work. Let mask this, how many 3/8 reducers would I need to slow it down. I'm owing to order them tomorrow. I appreciate all your help.
Itd be really hard for me to make it out that way , an its easily a days worth of work to replumb/wire the truck.
have you tried Floridatruckscene or Infamousnissan to see if anyone is closer that could help ?
I don't expect you to come to me. I would go to you. I'm on both forums.
I wouldn't have a problem with that , it just could end up being a day + ordeal.
So it could be easier to find someone closer .. Though I could help do it.
if i knew anything about wiring valves... id help you out too, im not even at the valve wiring stage in my build(or any stage at the moment). best belive if i did though i would
Its really simple (if you can see what color wires are) , ground one wire and hook the other one to the switch box lead.The Avs boxes are usually labeled with which is which.
Save it for when im at that part! theres no way ill remember!
I have to say that's a clean truck man!! wish u lived closer would love to see it in person.
Thanks appreciate it. Only 2 hours from Orlando
» installing a bypass (On/Off) switch onto an External speaker
» Installing Seizmik's Baja Light Bar!
» Pressure relief valves on float tubes.
» Changing float tube valves?
» Bigger tires on your lawnmower
Page 1 of 4
